Where can I check to see if I am running the latest versions of Java and Flash?
How can I check if I’m running the latest version of Java?
Java is an integral application to any web experience and is necessary to use some of Box’s core features (like Upload Folders). Check if you have the most up-to-date Java version running on your browser here:
If you do not have the most current Java running on your browser, you will be prompted to update by downloading, installing, and running the most recent release.
How can I check if I'm running the latest version of Flash?
Check if you are running the latest version of Flash here:
6 out of 6 found this helpful
