Uploading Files and Folders to Box
If you're accessing Box from your web browser, you can use one of three methods to upload files and folders:
Drag and Drop
  1. Drag a single file, multiple files, or an entire folder from your desktop to the Files and Folders screen. (Zipped folders must be unzipped in order to drag and drop them.)
    Note: Folder drag and drop is only supported in Chrome. For other browsers, use the Upload Folders option instead of drag and drop.
  2. Release the file(s) or folder. Your files will be uploaded and appear in the folder where you dropped them.
Upload Files and Folders using the File Browser
  1. Click the Upload button
  2. Click Upload Files or Upload Folders, depending on which you'd like to do
  3. Select the file(s) or folder you'd like to upload.
    Note: You can select multiple files for upload by holding the Command or Control key (Mac or Windows, respectively) while selecting files. However, you can only select one folder at a time for upload.
  4. Click Open or Upload
Upload Using Keyboard Shortcuts
  1. Navigate to the required folder.
  2. Type u to activate the Upload pop-up.
  4. Click Upload.
Uploading to Your Mobile Device
For instructions on uploading files and folders from your mobile device, read How do I upload files to Box from my mobile device?
If you're having trouble using the Folder Uploader from the Safari browser, see:  I Can't Upload Folders On Box While Using Safari On My Mac. What Do I Do?
67 out of 181 found this helpful
