Name:
Email:
Phone Number:
Issue Type:
How to disable auto-sync / set for manual Sync 3.x
At this time you cannot set your own schedule for Box Sync but you can turn off "Auto sync" and choose to sync manually.
If you have a Mac:
1) right-click the Box icon in the system tray at the top of your screen
2) click "Open Box Sync Preferences"
3) click "Settings"
4) uncheck the box next to "Sync Automatically"
5) click "Done"
If you have a PC:
1) right-click the Box icon in the system tray at the bottom of your screen
2) click "Settings"
3) uncheck the box next to "Sync Automatically"
3 out of 17 found this helpful
