Android - Can I Sync My Files on Box for Android?
Right now there is no option to sync files through Box for Android. If you need to access files for offline use, you can download the files locally to your SD card, or “save for offline use” so that you can access them through the app. Certain 3rd party apps like iAnnotate have built in syncing and may provide an alternative way to access files offline.
22 out of 35 found this helpful
