Android - How do I log in using my company credentials (SSO)?
To login through SSO, select the "Use Box Account Credentials" after clicking the "Log In" button on the main page.
Then enter the email address your Box account is registered under and you will be redirected to your company/University login page. Enter your company or University credentials there and you will be logged into Box.
0 out of 2 found this helpful
