Android - How Do I Save Files for Offline Access?
To access files for offline use, you can download the files locally to your SD card, or tap Save for offline use so that you can access them through the app. Certain third-party apps like Astro have built in syncing and may provide an alternative way to access files offline.
Please note: Offline files would no longer be available after you log out of the application.
4 out of 13 found this helpful
