How Do I View My Box Files in GoodReader?
GoodReader is a high quality file viewing app for the iPhone and iPad. It supports viewing of PDF and txt files and offers PDF reflow and in-text  search, among other features. It efficiently handles large PDFs, even those containing images. Additionally, GoodReader allows you to not only view files within your Box account, but also upload files to it from  your mobile device.
To use GoodReader, download it from iTunes or the App Store on your device. Open the app, then select "Web Downloads," then "Connect to  Servers," then Box Enter your name and password, leaving the "Readable  Title" field blank, and then press "Add." Your Box account will appear  at the top of the screen, and when you select it you will be able to  browse all your files and folders. To download a file, simply tap it once, and all your downloaded files will appear in the "My Documents"  screen.
To upload files from GoodReader to Box, go to "My Documents" and click  the "Actions" button. Select the file(s) you want to upload, then press  "Copy." Go into your Box account and press "Paste," and the files will  appear there.
 GoodReader uses WebDav to connect to Box, so you will need a Box-specific password to login and cannot use SSO.
 If you have issues with the GoodReader app, you can reach GoodReader support here.
0 out of 3 found this helpful
