Common Issues with Downloading Files
If you are encountering problems downloading files from your Box account, we recommend you try:
Other things to keep in mind:
  • Bulk download has a 5GB file size limit for Enterprise accounts, a 2GB file size limit for Business accounts, 1GB file size limit for paid personal accounts, and a 250MB file size limit for free personal accounts.
  • Files will download into the default location determined by your browser(ex. Downloads folder)
  • Downloaded files from Firefox will download in Read Only mode if the download option "Open In" is selected. If you would like to edit the downloaded file, please choose the Save As option when downloading the file.
  • If the option to download a file within a collaborative folder is not available to you in Box, then you may not have the proper Access Level for that collaborative folder to download the file. Please check your access level on the collaborative folder. If you are a Previewer, Uploader or Previewer-Uploader on the folder, you would not be able to download files in this folder.
  • When you download a folder from Box, the folder will download to your computer as a zipped file. You will have to unzip the folder once it has successfully downloaded to your computer.
If you still have problems downloading a file after running through these steps, please run a connection diagnostics test from within your Box account. Once you have done this, please submit a support ticket and let us know you have run a connection diagnostics test.
15 out of 55 found this helpful
