Print or Fax with Breezy
1.  Students and faculty are constantly running to and from classes, and often need to print a document or presentation last minute. With the Breezy app installed, users can print directly from their mobile device to any wireless-enabled printer on campus.  simply tap the Cloud icon on your Box file and select “Print and Fax with Breezy” to start the printing process. You'll then be able to select from among your own or your university’s wireless printers, the thousands of locations in the Breezy Partner Network, or even send your document as a fax.
Figure 1: Initiate actions directly from within your Box app.
Figure 2: Breezy supports the world's largest secure network of on-location printing partners.
Next: Access Files In Gmail Using Attachments.Me
Previous:  Print Notes On Your iPad With Notability
0 out of 1 found this helpful
