GAPS - What are we missing?
  • iPads and mobile devices can be easily dropped or broken on an active project site. Use care when working with fragile devices, or select a bring-your-own-device model to let people pick what tools they use.
  • Many users try to migrate all project content from their existing storage system to Box using Box Sync. This creates a suboptimal experience.
  • When choosing what content to sync offline, be sure to only sync the active and critical projects you are currently working on. Using Box helps reduce the demand and consumption of paper on job sites.
  • Legacy naming structures for documents such as 90.0008.12 – Boston might be familiar, but can be improved in Box by using a more robust and descriptive file name and descriptions.
Previous: Box for Construction- FAQs
Next: Box for Construction - Checklist
1 out of 2 found this helpful
