Empower Your Workers with Mobility
With Box on your mobile device, you will always have the most up to date company information in the palm of your hand.
Give your iPhone or iPad users access to the native Box for iPhone and iPad application. Using this app, they can easily store files online, send large files, access content and collaborate with others.  In addition, help mobile workers be more productive using the many other mobile applications for Box.
Box Mobile lets you:
  • Access, view and manage files directly on your device
  • Share files easily with a link
  • Quickly search for files and folders
  • Mark files and folders as favorites for easy access to content, even when offline
  • Secure content with file-level encryption, a four-digit passcode and automatic logout when the app is closed
  • Upload photos and videos to your Box account
  • Open and edit Box files in other apps installed on your device; save content directly to Box from more than 30 compatible apps
  • Wirelessly stream content using AirPlay (iOS)
Take Notes in the Notability App on Your iPad
Notability is a versatile app that allows you to capture ideas and notes with handwriting, text, and drawing tools. Use Notability to fully document all facets of a meeting.
Here are a few functions that you should test for your organization.
  • Select from a variety of brush styles and paper to capture handwritten notes.
  • Open and annotate PDF documents and save them back to Box.
  • Use bullet points, numbered lists, and spellcheck to take accurate and organized notes for sharing.
  • Click the Record button to record voice notes or the entire meeting.
  • Import existing notes and documents from your Box account into Notability for editing.
Figure 1: Notability is available in the App Store and works with Box OneCloud
Project From Your iPad Using SlideShark
SlideShark allows you to connect PowerPoint files from your Box account to their service using the Box Mobile app or web interface.
SlideShark maintains presentation formatting, including all fonts, transitions and animations, to accurately display your media-rich presentations.  Pharmaceutical reps can rely on this app when they present to customers, vendors and clients. You can also use it regularly for internal meetings.
Figure 2: SlideShark is a free app and works with Box OneCloud.
0 out of 0 found this helpful
