GAPS - What are we missing?
  • When you define security settings for a folder, consider what rights each user should have – for example viewer versus editor
  • Depending on your need to create and edit content, a tablet might not be ideal as a primary device. You can use applications like CloudOn and Quick Office, but many power users still find themselves using a laptop for part of their workflow.
0 out of 2 found this helpful
