Box and SharePoint - FAQs
Do I need to be a SharePoint administrator to make this work?
For best results and initial configuration, a trained Box and SharePoint administrator should complete all implementation.
Can I share SharePoint content to Box?
Yes. How you share content from SharePoint with Box depends on which strategy you choose. The easiest way is to embed a Box folder in SharePoint and share content from the Box embedded widget.
Can I use Box with my domain?
Yes, Box integrates with active directory and ADFS 2 to authenticate users and groups to Box. If you only have AD, other IDP’s such as OKTA or One Login can be used.
Does Box support Windows?
Yes, Box has native applications for Microsoft Outlook, Office, Windows Phone and Windows 8.
Previous: GAPS - What Are We Missing?
Next: Additional Information - Box and SharePoint
0 out of 0 found this helpful
