Migrate Content to Box from SharePoint
Moving documents and content from SharePoint to Box can be as simple as dragging and dropping files from Windows Explorer into Box. This is the best way to migrate a small amount of content from SharePoint to Box.
To start, navigate to the ribbon in SharePoint and select Open with Explorer.
Figure 1: Navigate from the ribbon in SharePoint 2010.
Next, drag and drop the files and folders that you want to move from SharePoint to a local storage location. For best results, select a local folder on your computer.
Figure 2: You can mount a SharePoint library through WebDav.
Before copying content to Box, you must remove any prohibited characters (\ / “ ; < > | * and ?) from file names. A tool such as Better Rename can automate this process for you.
Figure 3: Remove any unsupported special characters from filenames before moving them to Box.
Previous: Box and SharePoint - What Are My Options?
Next: Connect Box and SharePoint for Co-existance
0 out of 0 found this helpful
