GAPS - What are we missing?
  • SharePoint’s custom metadata, lists and content types do not have a functional equivalent in Box. When you move content to Box, your customizations will not be ported over.
  • Box does not support an equivalent to the SharePoint records center, although you can manage files and folders effectively in Box. If you require custom retention policies on content in Box, speak with your Box Customer Success Manager.
  • Workflows in Box are based on social interactions, task assignments and comments. In SharePoint, the options to create detailed workflow rules are fundamentally different.
  • Box is a multi-tenant cloud application and cannot be deployed on premise at a customer location. Every Box customer runs the same version of the product.
  • For best results, client PCs will need Internet Explorer 8 or higher.
Previous: Empowering Your Team and Common Adoption Challenges
Next: Box and SharePoint - FAQs
0 out of 0 found this helpful
