Box Notes: How Do I Create a Box Note?
Create new Box Notes from the Box web application. Just like any other type of document on Box, you’ll find your Box Notes in the folders were you added the new Box Note.
To create a new Box Note, follow this procedure:
  1. Navigate to the folder where you want to create the new Box Note.
  2. You can add a new Box Note using one of two options:
    • Click the New Note icon
    • Click New... > New Box Note.
  3. Enter the name for this Box Note and add a description as required:
    Your Box Note opens in a new tab or window in your browser.
  4. Start entering details in your new Box Note.
  5. Make your additions or updates without worrying about hitting the save button, we’re autosaving for you.
6 out of 6 found this helpful
