File transfer problems typically occur due to intermittent network issues. These problems can occur anywhere in the network and may be outside your control.
Environment
Resolution Steps
Depending on the type of network issue, you may need to contact your administrator, IT department, or wireless/internet provider to resolve the issue. Once the network issue is resolved, retry the upload/download.
client_swarm_kb
