Note: Depending on your Office version, the first time you open an Office file with co-authoring you may see a one-time login prompt. After logging in, Box is added as a Place and auto-save is automatically enabled. If you don’t see the prompt or auto-save isn’t enabled, you may have an older Office version, or the update may not have reached your environment yet. In this case, you can add Box as a Place manually using the steps below.
Configuring Co-Authoring for your Account
To start co-authoring, add Box as an online storage location from within the Microsoft Office desktop app. Follow these steps for your specific operating system.
On Windows
- From Microsoft Word / Excel / PowerPoint, click on File menu option.
- On the left navigation pane, click Open
- Click on Add a Place
- Select Box
- Select Single Sign-On (SSO)
- Sign in with your Box credentials
On Mac
- From Microsoft Word / Excel / PowerPoint, click File -> New from Template
- Click Manage Storage Accounts
- Select Box
Note: If you encounter an error in which one or more of the following conditions apply, review the integration configuration:
- EID is enabled for co-authoring.
- All users are enabled and are on the correct Microsoft channel.
- All users have added Box as a place in their O365 apps.
Determining Configuration
To determine whether Co-Authoring has been configured for your account, you can check for the following items:
In the Office menu, go to the Open tab and see whether Box is added under Other locations. If the app is added, the user's sign-in username is displayed.
Additionally, AutoSave is enabled in Office when opening co-authorable files.
