What is Box for Microsoft Office Co-Authoring?
Which file types are supported?
What Microsoft subscriptions are supported?
How does an admin enable co-authoring?
Should we enable it for everyone or only some users?
Do all collaborators and content owners need to be enabled for Co-Authoring?
Can Lite users use desktop Co-Authoring?
How does a user set it up in Office on Windows?
How does a user set it up in Office on Mac?
How can users confirm they are configured correctly?
Can admins auto-provision Box as a Place?
What happens during a co-authoring session?
Does file data go to Microsoft?
Why do Excel workbook links break?
How can we prevent Excel linked workbook issues?
How do users repair broken Excel links?
What are the major limitations?
Where should users start if co-authoring is not working?
How does Box for Microsoft 365 support organizations with federal compliance requirements?
Box for Microsoft Office Co-Authoring lets users edit Microsoft Word, Excel, and PowerPoint files stored in Box at the same time, with AutoSave saving changes back to Box. It works with Office desktop apps and Office for the web.
Supported file types include .docx, .xlsx, .xlsm, .xlsb, and .pptx.
Is Box Drive required?
No. Box Drive is not required for desktop co-authoring, though users can open files from Box Drive if their environment is configured correctly.
What platforms are supported?
Windows 10+, and macOS 11.5+. Mobile support is coming soon!
Supported subscriptions include Office 365 Enterprise K1/E1/E3/E5, Microsoft 365 Business Standard, Business Premium, Apps for Business, and Apps for Enterprise. Perpetual Office licenses such as Office 2016 or 2019 are not supported.
Admins enable and authorize Box for Microsoft Office Co-Authoring in the Box Admin Console. It can be enabled for the whole enterprise or selected users and groups. New Box customers have Microsoft Co-Authoring enabled by default as of July 28, 2025.
Enabling co-authoring for the entire enterprise is the preferred setting. Mixed configurations can cause problems, especially with Excel linked workbooks.
Yes. For Box for Microsoft Office Co-Authoring to work reliably, all users involved with the file should be enabled and configured for Co-Authoring, including both collaborators and the content owner. Users should also add Box as a Place or Connected Service in Microsoft Office and sign in with their Box account.
If some users are enabled and others are not, files may open in read-only mode, Co-Authoring may not start, or Excel workbook links may break due to mixed Office and Box configurations.
No. Lite users cannot use Box for Microsoft Office desktop Co-Authoring. They can still co-author Office files online by using Box for Office for the web, assuming the appropriate Box and Microsoft web configuration is enabled.
In Word, Excel, or PowerPoint, go to File > Open > Add a Place > Box, then sign in with Box credentials or SSO.
In Word, Excel, or PowerPoint, go to File > New from Template > Open > Manage Storage Accounts > Box, then sign in with Box credentials or SSO.
In Office, check the Open tab and confirm Box appears under Other locations with the user’s signed-in account. AutoSave should also be enabled when opening co-authorable files.
Yes. Box describes an admin-assisted approach for Windows users using the ms-office-storage-host:asp|d|TP_BOX_2|o|0|a|Web URL so users can add Box as a Place in Microsoft Office.
AutoSave is enabled, collaborators can see each other’s avatars and cursor locations, and Box applies a co-authoring lock so session participants can edit while outside changes are rejected.
How are versions created?
Box creates a new version when five minutes have passed since the last version, when a collaborator downloads the file within five minutes of the last version, or when a collaborator closes the document and completes the co-authoring session.
Yes. Box states that data for files being edited may be sent to Microsoft’s Office Collaboration Service to enable co-authoring, similar to Box’s Office Online integration.
Excel links can break when collaborators mix co-authoring workflows with desktop/local sync workflows. Co-authoring uses cloud URL references, while desktop sync may use local file paths such as C:\Users\Username\Box\...; switching between modes can create malformed or unresolved links.
Pick one collaboration mode for linked workbooks. If using co-authoring, require all collaborators to add Box as a Place and sign in. If using desktop sync instead, Box recommends a consistent Box Drive mount path for Windows users.
Open the destination workbook, go to Data > Queries and Connections > Workbook Links, choose the broken link, select Change Source, and point it to the correct source file location. Restoring a previous version may also restore links as they existed in that version.
Known limitations include no support for perpetual Office licenses, password-protected files, Microsoft @mentions in comments, changing Microsoft MIP sensitivity labels after enabling co-authoring, and files in folders with Hide Collaborators enabled.
Check that the enterprise is enabled, the user is enabled, the Office update channel is supported, Box has been added as a Place/Connected Service, and AutoSave appears for supported files.
The Box for Microsoft 365 integration allows customers with federal cybersecurity requirements to be routed to the appropriate Microsoft 365 environment. This ensures a fully compliant experience by processing and storing data exclusively on certified platforms. Please note that routing is determined by file ownership rather than the individual user's environment. If your organization has specific federal compliance requirements, please contact your Box Account team to guide you through how to get this configured.
