The Box mobile team is excited to introduce Capture Mode, a new way to launch the Box app directly into camera mode to start taking photos and uploading them immediately to Box. Once you add the new Box Capture widget to your device's home screen, tapping the widget will take you directly into Capture Mode where your photos are stored in a dedicated folder. Please refer to the instructions to add the widget. Capture Mode is available for the iOS and Android Box apps.
Capture Mode (iOS, Android)
Launched
