We're bringing the Box Agent and AI Home to the Box mobile app. Soon, you'll be able to use the Box Agent to turn your content into action, straight from your mobile device.
AI Home gives you a single place to work with your Box content using natural language. You can search across your files, get answers from documents, and create new content — all without needing to input where a file lives or specify which tool to use. You’ll be able to select sources directly from your Box content (including a Hub!), add content from local libraries, or upload captured media from your device to Box and immediately use AI Home to search, summarize, and work with them.
Your AI Home sessions are persistent, so your work doesn't disappear when you switch devices. Start a conversation on the web, pick it up on your phone, and continue right where you left off. Sessions are saved and searchable in Box, so you can return to any prior conversation, revisit an answer, or build on work in progress — whether you're at your desk or on the go.
Whether you're reviewing a contract before a meeting, pulling up a summary on the go, or searching for a file from your phone, AI Home on mobile puts AI-powered intelligence in your pocket. Every response is grounded in your Box content and governed by the same permissions and compliance controls already in place — so you get fast, trusted answers without any additional setup. The Box Agent and Box AI Home are available now for Enterprise Plus and Enterprise Advanced customers, included at no additional cost within usage limits.
Learn more about the recent Box Agent and AI Home announcement here
Box Agent and AI Home are coming to mobile
Launched
