We're excited to announce the release of the Hub Block in Box Apps. This is a new block type that makes it easy to connect your Box Apps directly to the Hubs your team relies on.
The Hub Block lets users browse and select any Hub they have access to and create a direct link to it within an App page. This brings your most important knowledge hubs into the flow of work, so collaborators can navigate to the right Hub directly from the App experience.
With the Hub Block, you can:
- Surface Hub access directly in your App: Add a link to any Hub you have access to, right on an App page.
- Streamline navigation: Give users a single, consistent place to access the Hubs most relevant to their work, keeping them in context and reducing friction.
- Keep your App experience connected: Tie together your structured App workflows with the rich, curated content living in your Hubs, creating a more unified experience for your team.
Setup
You can find the Hub Block within the "Blocks" section of the 'Configure App' sidebar.
Availability
The Hub Block in Box Apps is now available
