We're making it even easier to find the right solution for your business in the Box Solutions catalog.
Coming soon, you'll be able to:
- Install Solutions directly from the catalog with our first installable solution experience.
- Filter for Installable Solutions to find solutions you can deploy immediately.
- Identify Solution Providers at a glance, making it easier to discover who built and supports each solution.
Please note:
- Only Admins and Co-Admins with Box Apps, Metadata Templates Management, and Box AI access are able to install it
- At GA, IP Allowlist environments will not be able to install solutions
- No admin-level actions are required to simply browse solutions, but you can only install solutions if you have the permissions listed above
These enhancements are designed to help you discover, evaluate, and adopt Box Solutions with less effort and more confidence. Stay tuned for even more rich solutions available for installation this year.
