When attempting to transfer ownership of a folder to another user, you may receive the error "There was a problem while trying to transfer item ownership to {email}."
Common Causes
The error typically occurs as the transfer was blocked by enterprise settings configured by the Box Admin. Please reach out to the Box Admin to see if any of the following settings are enabled.
Restrict content creation
Same-enterprise transfers
- If this setting is enabled, admins (the main admin and co-admins with Manage Users or Manage Groups privilege) can transfer ownership of folders to managed users.
- Managed users generally cannot transfer ownership to others.
Cross-enterprise transfers
- Source Enterprise Restriction: If the source enterprise has Restrict Content Creation enabled, managed users cannot transfer folders to any internal or external users.
Destination Enterprise Restriction: If the destination enterprise has Restrict Content Creation enabled, managed users cannot receive folders at their root level.
However, admins (the main admin and co-admins with Manage Users or Manage Groups privilege) in destination enterprise can receive root-level transfers and subsequently assign them to the target user.
Retention Policy / Legal Hold
- You cannot transfer the ownership of a file or folder with a retention policy to an external user.
- For a relatively large folder (50 files or more), you cannot transfer the ownership to an external user regardless of whether any of the policies actually apply to the contents under that folder.
The Box admin can try the followings for each of the scenarios:
- Box Admin or Co-admin with access to Content Manager can perform the ownership transfer through Content Manager on behalf of the managed user.
- Source Restricted: Box Admin or Co-admin with access to Content Manager can perform the ownership transfer through Content Manager on behalf of the managed user.
- Destination Restricted: The original owner can perform transfer to the admin (the main admin and co-admins with Manage Users or Manage Groups privilege) in destination enterprise, who can then transfer it to the destination user.
- Files/folders under retention cannot be moved to an external user. In case transfer of a folder to an external user is blocked even though it doesn't contain files/folders that are under retention, you can try perform the transfer in a smaller chunk (less than 50 files at a time).
- If this does not work, please open up a case with our support team and provide the following information:
- Current owner
- New owner
- Folder ID
- Network capture while attempting transfer
