Users & Groups settings let you define who has access to your Box enterprise and when and how they access your Box content. It is available via Admin Console > Users & Groups. This topic contains the following sections:
Managed Users tab
The Managed Users tab lists all the managed user accounts in your organization. The columns in the list include the following user data:
- Name
- Email (default sort)
- User ID
- Role
- Last Activity
- Collaborations
- Status
- Storage Used
On this tab you can:
- Click on the Name or Email column header to sort the list of managed users by that attribute.
- Click Filter Applied to filter the managed user list by:
- All Users (default) - Lists the admin, all co-admins, and all managed users in your organization.
- Admins - Lists the admin and all co-admins in your organization.
- Co-admins - Lists users who have been assigned a co-admin role.
- Exempt From Device Limits - Lists users who are exempted from your organization's maximum allowed devices value, that is, who have the Exempt user from device pinning limits setting in the Role and Access Permission section enabled.
- Click Bulk Edit to edit multiple managed user accounts at once. See Configuring and Editing Users for details.
- Hover over a row and select the ... button. This gives the option to:
- Download User Engagement Report - Provides an overview of your user's storage consumption, file and folder count, and collaborations. Visit User Engagement Report for more information.
- Log in to this Account - Log in to and view the user's account.
- Add Users to Groups - Select a group to add the user to, then adjust the access level as needed.
- Make User Inactive - The user will no longer be able to sign in, and any content they own will become unavailable for collaboration until the account is reactivated. You can select to notify the inactive user at the email address in their managed user account.
- Make User Active - The user will again be able to sign in, and any content they own will become available for collaboration. You can select to notify the active user at the email address in their managed user account.
- Delete User - Make a user inactive, transfer content and workflows to another user, or delete the user and their content. More information is available in Deleting Managed Users.
Click a user name or double-click a row to view details about a managed user. At the top of the managed user details page is a summary that includes the managed users' avatar, name, email, and user ID. User metrics also display:
- Folder and Files: Lists active folders and files which the user owns.
- Last Active Date: The date of the user's most recent activity in Box.
- Groups: The number of groups that the user is a member of.
- Collaborations: The number of active files, including files within folders, in which the user is a collaborator.
You can select the more icon (...) to log in as the user, make the account inactive, or delete the user.
A managed user details page has the following sections:
User Details
This section lists the settings in the the User Details section of a managed user and describes each setting. (This section is named User Account Details in the legacy design.)
- Name
Required. Typically the name of the person to whom the user account is assigned to. The value in this field is used in reports and logging. Limited to 50 ASCII or double-byte characters.
Required. The email address of the user. This email address is where notifications, password resets, and other Box communication will be sent, and should be within your organization's domain.
- Notification Email
An additional email address where notifications for this account can also be sent.
In Admin Console > Enterprise Settings > Notifications > Email Notifications, the Allow all users to receive Box notifications at an alternate notification email address setting determines whether Box notifications can be sent to this email. And if that setting is enabled, the Allow all users to change their notification email setting determines whether users can change this email address in their own account settings.
- User Title
The value that the user entered in the Your Title field of the Profile tab on their Account Settings page. The value is not editable by admins on the User Details page in the Admin Console.
- Password
Does not reveal the value of the user account password. In this field, you can:
- Click Forgot password to send a notification email to the user with a link to reset the account password.
- Select the Require a change of password on next login check box to force the user to change their password the next time they attempt to log in to Box.
- If SSO has been enabled in your organization in the Admin Console, the value here is SSO enabled and there is no password action you can take here.
- Time Zone
Defines the time zone of where the user is located. Used to determine the correct date and time for user activities.
The user can also change the value of this setting on their own Account Settings page.
- Language
Defines the language the user will see in the Box user interface when signed in.
- Box Zone
Available when Box Multizones are being used, defines the zone in which the user's content is stored. If you do not manually assign someone to a zone, Box automatically assigns that person to your enterprise's default zone.
When you assign an existing user to a new zone, their existing files migrate to that zone and any new files and folders they create within their own root folder are mapped to the assigned zone. If they create a file within someone else's root folder, that file is mapped to the storage policy of the owner of the file.
Make sure you choose the correct SFTP endpoint for your region.
- Storage Used/Allocated
Indicates the amount of storage used (not available in the legacy design) and defines the total amount of storage, in gigabytes (GB), the user is allocated in your Box organization. Enter a number or select the Unlimited check box.
"Unlimited" is defined as up to the amount your enterprise subscription level contains.
- Status
Defines whether the user can currently work in your Box enterprise, and how. Select from:
- Active: User can log in to Box and use their account normally.
- Inactive: User is prevented from logging in, and folders owned by this user will be hidden from all collaborators. Inactive users still display as collaborators in other users' content (e.g. if the inactive user viewed another user's folder prior to being inactive, they are still displayed in the list of collaborators).
- Active View/Upload Only: User can log in to Box but cannot edit or delete content.
- Active View Only: User can log in to Box but cannot share, edit, or delete content.
- Account Created
Shows the date the user account was created. This value is system-generated and cannot be changed.
- Last Modified
Shows the date that the last change was made to the user account. This value is system-generated and cannot be changed.
Role and Access Permissions
- Role
Defines the user account role. Select from:
- Member - Allows access to Box with no administrative privileges. The member privileges include shared contacts, Box Sync, external collaboration, and device pinning.
- Co-admin - Available only with Business Plus and any Enterprise-level tariffs, allows access to Box with both member and co-administrative privileges. Selecting this option adds a section where you select the Co-admin permissions for this user, including access to users and groups, reports and settings, policies, metadata, and more.
Note
For security purposes, a user cannot be given the co-admin role if their primary email address in their user account uses a public (for example Gmail, Outlook, or Yahoo) or an unverified domain. See Verifying an Unverified Domain for information about how to verify a domain that you manage.
- Shared Contacts
Allows this user to access all other managed users in their contacts list when inviting collaborators. External users will not be accessible unless already collaborating. If you clear this setting, the user will access only the people they are actively collaborating with and will need to manually fill the contacts list.
- Box Sync
Enables the user to synchronize files between Box and their computer hard drive via Box Sync.
- Restrict External Collaboration
Restricts the user from creating external collaborations for folders they own.
- Device Pinning
Enables the user to be exempt from the maximum number of devices synchronized with their Box account value set for your enterprise in Enterprise Settings > Device Pinning.
- Relay Access
Enables the user to access the Relay page and create workflows on files or folders they own or co-own..
Co-Admin Permissions
This section lists the co-admin administrative permissions by functional area available for Business Plus and all Enterprise-level customers that you can assign users with the co-admin role. If your Box account is a Business plan or lower, co-admins do not have access to some Box features. Additionally, the following restriction applies:
- Cannot view or edit admin details
- Users and Groups
These options allow a co-admin to adjust user and group access to content as well as changing a user's settings. The settings include:
- Manage users: Add new users or edit existing user information and access levels. Selected by default.
- Manage groups: Create new groups, assign group admins, or edit existing groups. Selected by default.
- Content
These options allow a co-admin to log into users' accounts for auditing purposes. The settings include:
- Log in to users' accounts: Log in to any managed user's account.
- View Archives and users' content: Access any managed user's files and folders, as well as Box Archive.
- Edit Archives and users' content: Modify any managed user's files and folders, as well as Box Archive.
- Manage File Requests: Allows access for the File Request Dashboard and to share, delete or de-active the File Request from the dashboard.
Box Archive is available only to Enterprise Advanced accounts and currently supports only Folder-based Legal Holds.
Note
Co-admin's content access permissions override the platform apps permissions, including the Global Content Manager (GCM) scope.
- Hubs
These options allow a co-admin to take actions on Hubs for your company. The settings include:
- View Hubs for your company: Read-only access to your organization's Hubs.
- Manage, share, and delete Hubs for your company: Modify your organization's Hubs. Enabling this will automatically enable the View Hubs for your company setting.
- Reports and Settings
These options allow a co-admin to run reports and adjust the account as a whole. The settings include:
- View settings and integrations for your company: Read-only access to your organization's settings and applications.
- Edit settings and integrations for your company: Modify your organization's settings and applications.
Run new reports and access existing reports: Access existing reports and create new reports for your organization. This permission is required for a co-admin to:
- View the Reports page and configure and run reports from there.
- View the Insights page and configure any of the data tiles or run reports from any data tiles.
- Run the Collaboration report that is required to enable an information barrier.
- Policies
These options allow a co-admin to see and interact with policies for your company. The settings include:
- View policies set up for your company: Read-only access to existing policies for your organization. Select either Legal Holds and Retention or Legal Holds only.
- Create, edit, and delete policies for your company: Create, modify, or delete your organization policies. Select either Legal Holds and Retention or Legal Holds only.
- Automations/Relay
These options allow a co-admin to work with automations for your company. The settings include:
- View automations/Relay workflows set up your company: Read-only access to existing automation processes for your organization.
- Create, edit, and delete automations/Relay workflows for your company: Create, modify, or delete your organization's automation processes.
- Metadata
These options allow co-admins to create and edit metadata templates. The settings include:
- Create, edit, and delete metadata templates for your company: Create and modify metadata templates used throughout your organization.
- Shield
These options allow co-admins to create and edit Shield security policies. The settings include:
- View Shield lists and alerts for your company: Read-only access to Shield lists and alerts in your organization.
- Create, edit, and delete Shield configuration for your company: Create, edit, and delete Shield detection rules, access policies, and information barriers in your organization.
- GxP
These options allow co-admins access to the GxP Dashboard. These options include:
- View GxP Dashboard: View the GxP Dashboard, test results, and release notes.
- Sign
These options allow co-admins to edit Sign settings. These settings include:
- View and edit Sign permissions: View and modify Sign permission settings used for your organization.
- View and edit Sign legal settings: View and modify Sign legal settings used for your organization.
- Shuttle
This option allows co-admins to access Shuttle.
- Manage Shuttle: Use Box Shuttle to analyze and migrate data. Co-admins with this option enabled can only access Box user accounts to list existing content and add new content using Box Shuttle. They cannot manage Box user accounts in any way.
- AI Studio
This option allows co-admins to access AI Studio. Only available for Enterprise Advanced accounts.
- Create, edit, and delete AI agents for your company: Manage custom AI agents. Each agent can be configured with specific capabilities, access controls, and custom instructions. Learn more at AI Studio agents.
- Developer Platform
These options allow a co-admin to create and manage Sandboxes and browse Automation Templates. The settings include:
- Manage Sandboxes: Gives access to the Sandboxes tab to create, edit, and delete Sandboxes. Selected by default.
- View Automation Templates: Gives access to the Automation Templates tab to browse scripts that can be used in CLI. Selected by default.
Folder Collaborations
Lists the folders that the user has been invited to collaborate. You can adjust the widths of the columns in this section to view any truncated content. An admin can also click Edit and:
- Click Select New Folder to add folders to the user's folder collaboration list.
- Select one or more folders and then click Remove Access to remove the folders from the user's folder collaboration list.
Groups
Lists the user groups that the user is a member of. You can adjust the widths of the columns in this section to view any truncated content. An admin can also click Edit and:
- Click Select Groups and then either add the user to additional groups or remove the user from any groups that they are a member of.
- Hover over the group name and click Remove to remove the user from that group.
- Change the Access Level of the user in the group. You can select from:
- Member - User is allowed access to the group and its functions.
Group admin - User has group admin-level access to the group, which means they can edit group membership, content access, and settings. See Designating Group Admins for more information on configuring group admins.
Note
If a user is made a Box admin or co-admin, they will lose group admin status of any groups that they are a member of.
Managed Devices
List which Box applications available within your company can be used by the user.
This section was titled Installed Applications in the legacy design.
External Users tab
The External Users tab lists all unmanaged and external user accounts. Unmanaged users are collaborators that have accounts that use a managed domain but are not managed users. External users are collaborators that are not in your Box organization. They may not share your company domain(s) and are not subject to enterprise policies.
The columns in the list include the following external user data:
- Name
- Organization
- Date Added
- Last Active
- Collaborations
- Invite Status (if any have been invited to become managed users)
The drop-down list in the External Users tab allows to you view either all of your unmanaged users or all of your external users. In either list, you can:
Click the name of a user to view their details. At the top of the unmanaged or external user details page is a summary that includes the unmanaged or external users avatar, name, email, and user ID. An unmanaged or external user details page has the following sections:
User Details
The information in the User Details section of an unmanaged or external user is not editable and contains the following information:
- Name
Typically the name of the person to whom the user account is assigned to. The value in this field is used in reports and logging. The field may not have a value.
The email address of the unmanaged or external user. This email address is where notifications and other Box communication will be sent.
- Organization
For external users, if a member of another Box organization, displays that organization's name.
Lists the folders that the unmanaged or external user has been invited to collaborate. You can adjust the widths of the columns in this section to view any truncated content.
Platform Users tab
The Platform Users tab provides a dedicated interface for managing App Users. App Users are created via the Box API when building custom applications and cannot be created through the Admin Console.
This tab is visible to admins and co-admins with user management permissions.
Filtering, Sorting, and Search
On the Platform Users tab you can:
- Filter by User Type.
- Search by name or email using the global search to find specific App Users.
User Details
Click an App User name to view details. At the top of the details page is a summary that includes the user's name, email, and user ID.
An App User details page has the following sections:
This section lists the settings in the User Details section of an App User and describes each setting.
- Name
The display name of the App User. This field is editable.
- Type
Indicates whether the user is an App User or a Service Account. This field is read-only.
- Status
Defines whether the App User is currently active. Select from:
- Active: App User can access Box through the API normally.
- Inactive: App User is prevented from accessing Box.
- Storage Used
Indicates the amount of storage currently consumed by this App User. This field is read-only.
- Storage Allocated
Defines the total amount of storage the App User is allocated. Enter a number or select the Unlimited check box. This field is editable.
Displays the role and access permissions assigned to the App User.
Lists the folders that the App User has been invited to collaborate on. An admin can click Edit and:
- Click Select New Folder to add folders to the App User's folder collaboration list.
- Select one or more folders and then click Remove Access to remove folders from the App User's folder collaboration list.
Groups
Lists the user groups that the App User is a member of. An admin can click Edit and:
- Click Select Groups and then either add the App User to additional groups or remove the App User from any groups that they are a member of.
- Hover over the group name and click Remove to remove the App User from that group.
- Change the Access Level of the App User in the group.
- Assign the App User to a Group Admin role.
Admin Actions
When you hover over a row in the Platform Users list and select the ... button, the following actions are available:
- Download User Engagement Report - Provides an overview of your users’ storage consumption, file and folder count, and collaborations.
- Log in to this Account - Log in to and view the App User's account for testing or validation. Requires Admin or delegated permission.
- Add User to Groups - Select a group, then adjust the access to determine how the user interacts with the group's content.
- Make User Active - Means the user can sign in and makes any content they own available for collaboration.
- Delete User - Remove the App User. Requires user management permission.
Reporting
App User data is included under managed users in the User Details Report.
Groups tab
The Groups tab lists all user groups defined in your organization. Groups are listed in alphabetical order by name.
Click a group name to view details about the group. The group details page has the following sections:
Note: Changes to group membership, such as adding or removing users, may take up to 5 hours to be reflected in the displayed user count.
Group Details
This section lists the settings in the Group Details section of a group and describes each setting.
- Name
Required. The name of the group. It must be unique. The value in this field is used in reports and logging.
- Description
Optional additional information about the group. Use the Description field to summarize the purpose of the group, what users are in the group, and what the group has access to.
- Permission Setting
Defines which users in your account can invite this group to share content and view the members of this group. Select from:
- Company (default) - Anyone in your company can provide this group access to folders, view members in this group, and assign a task to members in this group.
- Group Members - Only group members can provide this group access to folders, view other members, and assign a task to members in this group.
- Admins Only - Only admins can invite this group to folders, view members in this group in the admin Console, and assign a task to members in this group.
Members
States the number of Group Admins and Managed Users in the group. Click Edit to see the members of the group in alphabetical order by name, as well as:
- Filter the list by name or email address.
- Add managed users as members to the group.
- Change the permission of a group member. For members who are not co-admins, you can select from:
- Group Admin - User has group admin-level access to the group, which means they can edit group membership, content access, and settings. See Designating Group Admins for more information on configuring group admins.
Folders
Lists the folders that the users in the group share. An admin can click Edit and:
- Filter the folder list.
- Click Add to add folders to the group.
- Change the access level of the folder. See Understanding Collaborator Permission Levels for details about each choice.
